AutoCAD Valve Drawings
Does anybody know where I can download double block and bleed valve CAD files?
RE: AutoCAD Valve Drawings
Do you want to bring them into CAD or just need the data?
I need to bring them into Autocad to use on a drawing.
Just use a normal valve symbol and put DDB under it. It does no good to get some highly detailed valve drawing and dump it into a piping drawing that is normally at 3/8"=1'-0" scale anyway ...you don't see anything and with all the detail it'll just plot out as a black "blob"!
