ASTM A105 & A350 Size Range
Can anyone tell me what piping size range applies to ASTM A105?
Also, what range for A350?
Thank you
RE: ASTM A105 & A350 Size Range
All and more.
The ASTM specs don't limit size, as stanweld has said, but speaking of common piping components and common commercially available commodities:
For valves and ASME B16.11 fittings, expect to see forged material at 4" and smaller sizes and 2" and smaller most commonly.
Forged valve bodies are less uncommon above these sizes.
Flanges and integrally reinforced outlet fittings of all sizes are forged standard.
Am I leaving any items out?
- Steve Perry
http://www.linkedin.com/in/stevenhperry
This post is designed to provide accurate and authoritative information in regard to the subject matter covered.  It is offered with the understanding that the author is not engaged in rendering engineering or other professional service.  If you need help, get help, and PAY FOR IT.
Steve, I believe that covers it and thanks for the detailed explanation.  Greatly appreciated.
