Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This site is like first coffee in the winter morning..."
Geography
steambreath (Mechanical)
4 May 11 21:07
WE must layup our boilers, generator, turbines and Balance of plant for long term cold weather survival.  Any suggestions??
JEB66 (Mechanical)
5 May 11 6:27
Have you discussed how to ensure that these systems are completely dry?
Any water left in the system will cause localized corrosion that could fail catastrophically.  Drain lines, make lines... typically run through people space.  If you cannot ensure complete drying, then then you could use an N2 blanket.
Try to use the heat of operation to drive the moisture out when removing them.
rmw (Mechanical)
5 May 11 22:21
You might consider the use of dehumidification equipment for the boiler furnace and back end.  Munters has a product.  Just google "munters" and "dehumidification".  Lots of hits.
I recommend N2 blanketing if you have any steel tubed FWH's.
rmw
Close Box
Join Eng-Tips® Today!
Join Us             Close
