Old Anchor Materials
Does anyone know what was commonly used for anchor rod material in the early to mid 1900's?
What were the strengths of these materials?
RE: Old Anchor Materials
Just the recipe the local blacksmith made in his shop.  I am unaware of any specs - so no idea.
I'm only talking circa 1930
Toad:
It seems you spend a good deal of time in and around old mill bldgs. and the like, from some of your questions.  You might do well to see if you can get your hands on a copy of a couple old books which were my Father's ref. books.  I'm not quite that old, I inherited them.  "Carnegie Pocket Companion for Engineers, Architects and Builders," Carnegie Steel Co., 23rd Ed., 1923.  And, "Architects' and Builders' Handbook," by Kidder & Parker, 18th Ed., 1931, John Wiley and Sons.
Kidder & Parker show the following for pins and bolts: Wrought iron, 12ksi tension, 7.5ksi shear & 15ksi bending; Steel, 16ksi tension, 10ksi shear & 20ksi bending.  They used a net area which was probably at the root of the threads, because a 1" dia. had a net area = .55sq.in. and a 2" dia. had a 2.302sq.in. net area.
The Kidder & Parker book has some really interesting section on Steel, Concrete, Timber design from that era, as well as Rivets.
dhengr-
I have a few colleagues with some of those books....thanks for the input.
Yea, I do a fair amount of work in mills and old industrial buildings as well as newer mills and manufacturing plants...some of the other things I get involved in (homes, foundations, substations etc) are completely on the other side of the spectrum.
One thing I been meaning bring up as a discussion here is the level of detail in old mill buildings. Analyzing these things can certainly open up a can of worms. Sometimes it is hard to find a reasonable stopping point.
Any thoughts dhengr?
I don't think a lot of guys from my era have any idea how intricate these buildings are.
