changing from UNC to UNF torque & applied force difference - SET SCREW
Hey guys,
I'm new here, so I hope this is in the correct area. I have a question about torque of a SET SCREW as it relates to force applied. Specifically in machine tool holders (endmill holders).
It has been decided to change from course thread to fine thread set screws on the holders, but the question remains is what to torque the set screws to?
set screws:
was 3/4-10 x 3/4" long 120ftlbs torque
is 3/4-16 x 3/4" long ? torque
Is there a formula that can determine what the conversion from course thread would be? I've done a search but havent found anything yet on set screws. Everything I have found is based on Bolts (with a head) or nuts.
Scott
set screws:
Scott
RE: changing from UNC to UNF torque & applied force difference - SET SCREW
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Scott
So the areas of the head or tip or whatever don't come into it do they?
Thanks for the quick replys!
Scott
list 140 and 120. I would think
the same would apply to setscrews.
Mike
PS - Ratio of root diameters x 120 = 140
Are you saying it will take 140ftlbs of torque on a fine thread screw to match the holding power of 120ftlbs of a course thread screw? It just seems backwards to me, I thought fine thread screws required LESS torque to obtain the same holding power.
Thanks again,
Scott
I have heard you can take the Ratio of TPI x torque to get the resulting torque of the fine thread fastener. Is this an accurate statement?
Thanks again,
Scott
Have a look at this link:-
ht
under the sub heading "intial bolt tension" at the bottom of that section it as a formula for tightening screws taking the pitch of thread into account.
desertfox
