Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...with companys cutting back on training, lack of true support by makers of software, the forums are a great tool in your cyber-toolbox...."
Geography
jesselai23 (Chemical)
4 May 11 0:37
When the number of tray for distillation column is determined in hysys design(e.g., 5), how many additional trays are added in the actual plant (5+2)?
maddocks (Petroleum)
4 May 11 16:52
wow, this is a huge question.  You need to get a copy of Kister's Distillation book and scour the sections on tray efficiency, performance and on and on.
Depending on what the column is doing, you may need as much a 3X as many trays as you've estimated.  Start by googling tray efficiency and then keep going.  Read papers from the Distillation Group - there's a ton of info out there.  Check GPSA, call a vendor, even better, try modelling the same tower to check actual efficiency.
Latexman (Chemical)
4 May 11 21:31
What components are in the system?  Pressure?  What type trays?  Is this for Unit Ops class or lab?
Good luck,
Latexman
Helpful Member!(2)  sheiko (Chemical)
4 May 11 22:42
What are you trying to do? designing a new column? troubleshooting or modelling an existing one? Is it a classroom exercise?
"We don't believe things because they are true, things are true because we believe them."
sheiko (Chemical)
4 May 11 22:45
In any case, I would rely on Hysys outputs - but only at conceptual stage of the project. I would never establish my proposed design based on the results from Hysys/Tray sizing, or on any other commercially available tool.
For designing/revamping distillation columns, one needs to go to proper address: tray/packing vendors, such as Sulzer, Koch-Glitsch, ACS, etc.
5 May 11 0:49
Thanks. Now I got ideas.
Close Box
Join Eng-Tips® Today!
Join Us             Close
