Calculate the forces in the reacion with the FEM module
Hi all!
I have an aluminium plate with some non homogeneity weight on the top.
Under it, there are 4 legs sustaining it.
I can get stresses and deformations easily (sewing surfaces, applying forces, clamps...).
But what i would like to know is the force in the reaccions. I have a limit of Kgs i can't exceed per leg.
This is a problem of classical mechanics, I wonder if it can be solved with Catia FEM
Thank you
Thank you
RE: Calculate the forces in the reacion with the FEM module
Marco
I had 4 legs, 4 sensors and I made an excel in order to check 3rd lay of newton. it works!
thank you!
right click on the sensor node and at the bottom you find different options.
The one i used for the reactions is
create resultant sensor - reaction sensor
Then you select the clamp
Cheers,
David
I realized that for a table with 4 legs I have to set 4 different clamp
Marco
If you have to select a specific area, 4 sewed surfaces, 4 clamps
cheers,
david
