PDMWorks behaving badly. How do I beat it into submission?
Howdy all,
So I've installed SolidWorks PDMWorks to play around with it and learn it's capabilities and there is one thing that really annoys me. If I check something out of the vault, do whatever updating I need and then check it back into the vault it says files need to be saved before checking them into the vault. Click O.K. and it saves them to what ever the current working directory is in SolidWorks which is usually a different project that I have not included in the vault. Shouldn't it save it to some directory under where the vault is located and not in the directories of non-vault projects? Are these files that it has saved now the files it will go to when I check the document back out again? It's like SW and PDMW are crapping my files all over my directory structure and I don't know how to whip it in line.
I'm new to PDMW and the help files are not particularly helpful. Is there a document out there that explains effective ways to set up and use PDMW, with best practices and perhaps a tutorial?
Thanks for everyones help and suggestions.
-Kirby
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
RE: PDMWorks behaving badly. How do I beat it into submission?
However, if a file is already in the vault, the workflow is completely different. You'll have to go to that file within the vault, RMB click on it to take ownership. Then RMB click on it again to change the project. Then find the file in the new project and RMB click on it again to release ownership.
Also, I recommend only using one folder on your local harddrive, such as C:\PDMfiles as your working folder. The vault maintains the projects, so you no longer need to do that on your harddrive.
Matt Lorono, CSWP
Lorono's SolidWorks Resources & SolidWorks Legion
Follow me on Twitter
SolidWorks Workgroup PDM Options...
Go to the folders tab, select the radio button and enter a value in the Use folder field.
Eric
-Kirby
Kirby Wilkerson
O.K. I did that, and I created a 'temp vault files' directory. but are these files the copies it is using? Do I need to set this directory for each project or is it the same for all projects?
I will continue to fiddle with it to learn it.
-Kirby
Kirby Wilkerson
Matt Lorono, CSWP
http:/
http://he
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
