gauge table for sheet metal
I am trying to create a gauge table that loads into Solidworks that picks the gauge, default radius, and applie the correct k-factor. I have created the table but get an error in Solidworks. Does anyone have a table I could spingboard off of to manipulate number to match our vendors suggested k-factors?
RE: gauge table for sheet metal
Why not use the ones that come with SolidWorks? You should be able to find them around <install_dir>\lang\<language>Sheet Metal Gauge Tables\
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
It may be helpful to say what the error message is, too.
Jeff Mirisola, CSWP
M9 Defense
My Blog
The error message is "The thickness of this bend fell outside the bend allowance/deduction table. The bend allowance/deduction is evaluated using the K factor instead."
I thought that I had the K-factor input in my table. This is why I was looking for a sample to see how the table is properly populated.
