stainless steel rod
stainless steel rod
Hello
anyone has design with stainless steel rod?
I need 1/2" or 5/8" dia rod.
what's the Yeilding strength and tensile strength for stainless?
please tell me value or market site.
RE: stainless steel rod
Fy is dependent on the alloy. Two of the common alloys, 304 and 316 yield strength is ~35,000 psi.
For small quanities try reviewing prices at:
http://www
If you need higher strength you can use 17-4 in a heat treated condition based on ASTM A564 Type 630.
If you are attempting to follow a bolt specification use ASTM F593 and F594 - typical threading manufactures and Fastenal will provide SS bolts/washers/nuts to this specification.
