switcher duty cycle - high or low?
I'm a bit rusty as it has been about 10 years since I last looked at switcher designs.
I need a 3.6V (+/-10%) 2.5A. I can tap it off a 5V supply (~75% DC) or a 24V supply (~15%). Which would you recommend?
I've read recently in a Linear Tech App note that subharmonics are more of an issue when the duty cycle is over 50%, so that makes me lean toward the 24V solution. Then I suspect I may get into discontinuous operation and have hurdles there too.
Z
Z
RE: switcher duty cycle - high or low?
The 24 volt would probably be the simpler implementation since you could benefit from the single pole response of the current mode controller operated below 50% duty. An additional advantage is that the input current would be much less and therefore much smaller IR drop on the input wires. The only disadvantage I see is the control resolution is less at a low duty cycle.
For tutorial on power supplies please see:
htt
Bob Stowe
President,
True Power Research, LLC
www.TruePowerResearch.com
Z
