Galvanic corrision betwen brass and galvanized steel
G’day,
Can anyone tell me if it is practically acceptable to use brass and galvanized steel fittings in contact with each other, or will this lead to excessive galvanic corrosion? The fluid passing through the fittings is water and it is not a particularly corrosive atmosphere (coal prep plant)
RE: Galvanic corrision betwen brass and galvanized steel
This depends on the relative area of each.
Here is some information
http://www.eaa1000.av.org/technicl/corrosion/galvanic.htm
http://www.corrosion-doctors.org/Aircraft/galvseri-table.htm
FAQ338-78 Galvanic Series Chart
