Flatten part for sheet metal cutting
I purchased a company and got all of their drawings as well, Some are in Autocad and some are in Inventor. I have a few drawings that I need to get manufactured and I'm not sure how to flatten the drawings for the cutter.
I'm good with autocad but not inventor (Scheduled for classes at the end of this month for those about to tell me I need training), I can create a part (cone) revolved to 359.5 deg and flatten it, that works. But the parts I received the drawings from don't have the welding butt. I'm attaching the part, how can I flatten the 2 rings and the cone separately?
Ron
Ron
RE: Flatten part for sheet metal cutting
Ron
Also I will NEVER give a flat pattern to an outside vendor unless I have been given accurate K factors,etc.. It is their job to make your part per "as formed" print. I never like opening up the possibility that a part is made wrong or they need to scrap parts,etc.. and then they can blame me because I supplied the flat pattern.
The need Autocad drawings for the CNC otherwise the charge me a cad fee.
Heck my sheet metal vendor would just take a step file of the file you posted only and take it from there (with no additional charge)
But like rollup already said if you want to fix that you would derive that file into 3 parts and fix those holes and use rip or whatever to create a flat pattern.
