Sealing system material
We are designing a sealing system for a tripper discharge in a coal thermal power plant (these discharge the coal in the coal chutes). The tripper will discharge the coal over a neoprene sheet. We need a material that allows the neoprene sheet to recover its position (horizontal position) once the discharge of the coal has finished in order to maintain the sealing function of it. I was thinking about an elastic metallic strip join to the sheet to achieve that. Because of the characteristics of the area, we need something easy to install and maintain.
RE: Sealing system material
Sorry again if I can´t explain correctly my situation.
You do understand that neoprene is synthetic rubber. ... right?
Mike Halloran
Pembroke Pines, FL, USA
Contacting a special company for advanced rubber-compound solutions seems to be the best idea, for instance:
http:
This is like a trapdoor for a coal stoker, is that correct?
