sldprt files required with sldasm file in 2011
I an running 2010.
Someone sent me a sldasm file of size 1.5 meg, but no sldprt files.
Is there a way in 2011 that they actually sent me something useful with only a sldasm file, or do I still need the sldprt files (assuming I had access to 2011)?
RE: sldprt files required with sldasm file in 2011
2. If you are on 2010 and the sender is on 2011 the simplest thing they can do is save the assembly as a single Parasolid file and send you that. Everything will be there, but in a dumb solid form.
- - -Updraft
Have you tried opening it?
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
