OEE - HOURLY CALCULATION
As we all know OEE is a multiplication of Availability, Performance and Quality.
There is some debate here on what formula it should be used to calculate OEE every hour. We are a one piece flow environment having the automotive industry as a customer.
Here are some of the formulas that our corporate office came up with:
 OPTION 1:
 The OEE by hour calculation should be:
 The total number of good parts produced for that hour/the goal
 of parts for that hour.
 The goal is calculated using the available time we are running
 during the hour/the Takt time.
 OPTION 2:
 The hourly OEE calc is:
 Total assemblies produced - Rejects /Standard machine capability
 for one hour
Also during a visit at the plant near our corporate office I saw OEE majority over 100% and I was very surprised knowing that 85% is considered "World Class"
What are your thoughts on this metters?
Your comments and help are highly appreciated.
Best regards,
Rabdatorul
RE: OEE - HOURLY CALCULATION
Interesting.
Option 1 seems like it could be well over 100% depending on factors in the equation. When ever I see "goal" as part of a metric I get worried.
The "goal" of parts per hour varies? That just doesn't seem right.
I would say Option 2
what can you produce, how much is good, and how much could you produce if everything was "reasonably" perfect
my machine is capable of putting out 100 parts an hour
I make 98 but 1 is bad. I am at 97%
StrykerTECH Engineering Staff
Milwaukee, WI
http://www.stryker-tech.com/
Option 1 seems closer to the classic calculation.
Option 2 seems like it has the potential to hide issues with rejects by cranking out numbers.
I would stick to the classic calculation of OEE and give visibility to all three areas of importance
Quality % - Rejects
Availabity % - Machine/Production Uptime
Throughput % - Machine/Production Stability
I've seen 100% plus OEE at some manufacturing facilities.  This could be a symptom of not setting appropriate standards to measure production.
Rich.....viking2
Richard Nornhold, PE
http://www.personna.com
