Weld Repair in HAZ
Weld Repair in HAZ
I have a set of 10" WNRF 600# flanges on an superheated steam line (765 deg F service temp) that need to be replaced The existing pipe is A335 Gr. P1 Sch 40 (P No. 3, 1/2Mo, no Chrome). The flanges are A182 F11 (P No. 4, 1-1/4Cr, 1/2Mo). There was no PWHT on the original welds nor do we plan to perform any on the repair. 250 deg F preheat will be maintained during the replacement as it was on the original welds. A GTAW/SMAW procedure with ER80S-B2/E8018-B2 filler will be used.
Is it advisable to avoid the HAZ of the original welds? Any studies you can site one way or the other would be helpful.
RE: Weld Repair in HAZ
Let your acquaintances be many, but your advisors one in a thousand' ... Book of Ecclesiasticus
Second-best choice it to make sure your HAZ does not intersect with the old HAZ.
