Flatness VS Straightness on Surface
Please ref to the attached figure, which one should be specified on the print? Flatness or Straightness on Surface ? What is the difference between them?
SeasonLee
SeasonLee
RE: Flatness VS Straightness on Surface
Most often, flatness is used.
Dave D.
www.qmsi.ca
Actually this is very similar case to circular vs. total runout or profile of a line vs. profile of a surface dilemma.
Tolerance zones for straightness, circular runout and profile of a line are two-dimensional while tolerance zones for flatness, total runout and profile of a surface are in three dimensions. If you are interested in controlling each (linear or circular) segment of a surface independently go for the first group, but if whole surface needs to be controlled second group is much better option.
The feature control frame is directed to the surface because it is a surface control. Straightness on the surface is a single line element control, but it is a series of single line element control on the surface, so we can consider it is a surface control, my question is why not to specify flatness directly? What are the differences between them?
Thanks again
SeasonLee
Flatness keeps all linear elements within common 0.2 tolerance zone and this zone can float within 0.6 size tolerance. It means the difference between perfectly straight linear elements can only be 0.2 in extreme case. So if one line is at 29.7 level, second one can be at 29.9 maximum.
Straightness only applies in the view where FCF is specified, which means in one direction, allowing for part shown in the picture.
Unless this is the design intent, you are better off with flatness.
If your part has really large length-to-width ratio, specifying different straightness in second view will make sense too.
Also features that are straight, but not flat, like round shafts are obvious choice.
John-Paul Belanger
Geometric Learning Systems
No it doesn't equal the same.
From a 3 point set up on the surface, we have a 0 to -.2 all in one direction giving us a straightness of 0.2 in that direction while in the other direction we have a 0 to +0.2 giving us a straightness of also 0.2 but combine your readings and one achieves a flatness of 0.4.
Dave D.
www.qmsi.ca
John-Paul Belanger
SeasonLee
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
From a functional viewpoint, perhaps where there is a sealing surface, and you're worried about fluid leaking through any valleys in a surface.
John-Paul Belanger
you DEFINITELY need a spell checker. or rely on a checker.
tk369..a checker!
ted kralovic
VisVSA, NX-6, Macbook, iPhone 3GS, among others
To tk:
I would immediately follow your advice, as soon as I find checker who doesn't forget to capitalize beginning of the new sentence.
Not to mention his own name.
Also, I don't understand, are you suggesting flatness or straightness? It is not the best way to start conversation with personal rant not related to the discussion on the forum.
I think you definitely need a moderator.
"Checkers, checkers everywhere" – read in the voice of Cartman from South Park.
