Single Line Diagram Fonts
For the small article what I have to prepare as Word (.doc) document, I want to insert two/three simple Single Line Diagrams
( breaker, transformer, recloser, buses, short circuit symbol etc.)
How to do that ? Also, how to insert there a text tagging transformers (T1,T2), buses (B1,B2) etc. ??
RE: Single Line Diagram Fonts
Rafiq Bulsara
http://www.srengineersct.com
If you need to create a simple diagram inside of a MSWord document, there is a Draw function inside of Word the gives you simple tools for creating images. This also gives you the ability to edit the drawing as well. I use that all the time and over the years I have created and saved a separate document that is essentially a library of symbols and shapes that I can copy and paste into new documents. saves a lot of time. But as far as I know, nobody sells a Word symbol library for electrical work. The drawback to using the MSWord Draw function is that it is tedious to use so if the drawing is complex, it can be a real drag.
If the drawing is more complex, MS Visio is available with electrical libraries, and you can freely export Visio drawings into Word documents as objects, then edit them inside the document later, as long as it's on the PC that has Visio on it. it's very seamless and I highly recommend it if you will be doing any extensive work like that.
"Dear future generations: Please accept our apologies. We were rolling drunk on petroleum."
— Kilgore Trout (via Kurt Vonnegut)
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
