Existing Z roof gurts
I am looking at a project where Z girts, spanning 25', spaced 5' apart were used on a storage building. They want to some new RTUs on the existing structure.
While doing other field measurements I also did a quick check of the Z girt (3"x8"x3") but I am not sure if I got the thickness right. I came up with 0.15" thick which seems high. I have noticed that some Zs have a tiny lip at the end which may end up with an inaccurate thickness using VernierCaliper so I may go back and use a metal gauge.
But my question is, Is there a source where I can look up similar girt's member properties to see what gage and grade may have been used. The building is from the late 80s.
Kaiser
RE: Existing Z roof gurts
Kaiser
As has been discussed numerous times in the forums - these buildings are designed with little or no reserve. I am am actually afraid to walk on some of them.
Even a 200 lb RTU might be impossible. Try as you might and I wish you good luck.
BA
I think you're right though. I've never seen Z girts that thick. Double check your measurements.
Mike Halloran
Pembroke Pines, FL, USA
