Negative pressure in Room and air balance
I have a doubt:
If a have a negative pressure in a room, does it suppose that i have a negative air change?
Because my extraction is bigger than my inyection of air to the room. these is rigth or not?
I have to report my air changes in a pharma instalation and i have that doubt.
Please help me.
Sergio Avila
Please help me.
Sergio Avila
RE: Negative pressure in Room and air balance
If you have a little negative pressure in a room, it is still positive to the general universe and likely to atmospheric pressure... and some other space closer to the supply fan.
Negative pressure can be obtained with any number of air changes - air changes can be had as long as there is air passing through a room. Look at your air flow and calculate the air changes based on that data and the volume of the room.
Biological production units maintain areas negative with respect to atmosphere, particularly when viruses or GMO are being handled.
Sergio,
You calculate ACPH based on supply flow rate and not net flow into the room. ACPH indicates how many times your room air is being refreshed (by filtration) to maintain the required particualte level.
If you are handling viruses, you would probably be in a BSL-2, 3 or 4, which is an entirely different requirement from the BMBL.
If positive, I count air changes by supply for the ISO ACH requirement, and look for a 0.05 IWG at balance by dampering the exhaust. For negative I go by ISO ACH requirement on the supply side, and damper back the exhuast at balance for the 0.05 IWG. A magnahelic on the wall before entry should be considered for operations. Differential flow indicates relative differential pressure. The amount of flow difference needed is reflective of the leakiness of the enclosure.
http://www.eng-tips.com/viewthread.cfm?qid=43928
