Diff. Between SA 387 Gr.11 CL1 and Cl.2 material
HI all,
Can anyone tell me the difference between SA 387 Gr.11 CL1 and Cl.2 material and their usage in pressure vessel design
RE: Diff. Between SA 387 Gr.11 CL1 and Cl.2 material
Class 2 plates will have a higher minimum tensile and yield than the Class 1 plates.  If you can get a copy of the SA-387 spec, you will see.
I believe that the Class 2 plates will therefore have higher stress values that can be used in the design calculations.  This can be verified in Section II, Part D, I don't have a copy of that handy.
Yes, higher allowable stress values apply for Class 2.
Thank you very much for the guidance
