Error message during Detail View creation.
During a Detail view creation, the follow error msg appears "An attempt was made to associate an object with a second other object", this window wasn't appear before during other detail views creation on other similar drawings, is there setting I must turn on before proceed with this operation? Is this a problem associated with my PC?
Thank you!!!
RE: Error message during Detail View creation.
What version of NX are you running?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
It's NX5.
Thanks for your reply!!!
Without seeing the part file, it's hard to say what it might be.  You will probably need to contact GTAC and have them look at it as it very well may be part specific as there are no options that I'm aware of which would impact details view creation (there actually are some in NX 7.5, which is why I asked about your working version).
John R. Baker, P.E.
Industry Sector
Cypress, CA
I am having the same error message, but it occurred when I tried to open a part that I had previously saved. There is no drafting in my part, only modeling.
I am running version 7.5.
Let me know if you find a solution.
The file presenting the error is attached.
Your best chance of finding a solution to a problem like this is to contact GTAC and submit your files and syslogs.  For issues like this, there is very little that you will learn from a 'message board' other than perhaps what someone else learned when THEY contacted GTAC.  So why don't you cut out the 'middleman' and go directly to the source...
John R. Baker, P.E.
Industry Sector
Cypress, CA
