Insight transaction problem
I have a problem whit Insight, my files "get stuck" in the cache and I can not check them in. When I to open the files I get the error message:
"A transaction is currently being processed on this file. You cannot perform a new transaction on the same file until the first one is completed."
I have tried to check in/delete them manually from the Cache Assistant but I get the same error there.
RE: Insight transaction problem
I run Solid Edge ST3
http://www.eng-tips.com/viewthread.cfm?qid=277255
Check the above thread. You need to delete the "translog" file as described.
Theodore
Solid Edge ST3 MP3 on WinXP x64
Insight Server on Win2008 R2 & SQL 2008 R2 x64
SharePoint 3.0 x64
Thank you Theodore! That fixed my problems.
/Stefan
