Calculating Dry Density in Excel
Hello All ...
I am trying to create a spreadsheet for sand cone testing that will perform some of the calculations. I am stuck at imputing a formula to calculate the dry density . Does anyone know how to input that formula ?
 Thanks for any help ....
RE: Calculating Dry Density in Excel
=DryWeight/Volume
or if using metric,
=DryMass/Volume
and if you only have the wet weight, divide the wet weight by (1+(w/100)) where w is the whole number (percent) to get the dry weight. BTW, w is the water content.
