Mating Threads
Mating Threads
When designing threaded parts that mate together, (for example a threaded bottle neck and a cap), are there generally gaps or spacing anywhere designed in to for tolerances? Or are the mating threads line to line? It seems like there should be some sort of gap but im not sure.
Thanks!
Thanks!
RE: Mating Threads
Mike Halloran
Pembroke Pines, FL, USA
RE: Mating Threads
RE: Mating Threads
Can you recommend any websites or literature showing mating thread profiles?
Ryan
RE: Mating Threads
I.e., .010" or so.
There are 'standards', but I've had better luck just detailing a part to mate with whatever part I could buy.
Mike Halloran
RE: Mating Threads
So, rather than talk to a mech engineer about threads - as if this was a conventional thread problem, I'd recommend talking in depth to the design/fabricator company of the bottling machine that you will use.
RE: Mating Threads
If you are designing a custom cap to fit a commercial bottle, or conversely, I stand by my advice. It's worth at least what you paid for it.
Mike Halloran
RE: Mating Threads
http://www.plasticbottle.com/techinfo/spi.html
Ted
RE: Mating Threads
RE: Mating Threads
If at all possible start with one of these.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
