Going from SolidWorks to Catia
I've been using SolidWorks for years, and recently changed jobs where they use Catia. Any quirks I should look out for? I got a few tutorials from a coworker. Are there any good tutorials out there that might be recommended? Thanks!
Jeff Parham
Structural/Mechanical Engineer
RE: Going from SolidWorks to Catia
Tip 1) Catia is not SolidWorks. I should probably repeat that. Don't let the name on the box fool you; ignore the fact they both say Dassault. The two programs are fundamentally very different. If you spend all your time asking why Catia doesn't behave like SW, you will end up frustrated and grumpy. Better to invest your time learning how Catia works.
Tip 2) Search this forum for the word "SolidWorks," I think you'll find a lot of answers to your questions. It's not the first time for someone to transition.
Tip 3) Catia has a multitude of Design-In-Context features that are very powerful, but also have lots of rules. I suggest you get really comfortable with V5 before letting yourself start creating all sorts of links between parts and products.
And the last one, just for fun, they're called "constraints" not "mates." :)
Cheers,
Mark
Certified SolidWorks Professional
