Opening TCE NX7.5 Drawing Error (Freed Object...)
NX7.5 in use.
When opening a Specification file with NX7.5 open I get the following error messagae:
"Could not open AGE16770_99167/00 (specification: DWG_AGE16770_99167/00).
The following files could not be loaded causing this open to fail:
AGE16770_99167/00 (specification: DWG_AGE16770_99167/00) – Attempt to write to freed object
OK"
The drawing will not open. If I open the model assembly first and then the drawing, no message is given and all opens as it should. Can anyone give me a clue as to what is going on?
Thanks.
OK"
Thanks.
RE: Opening TCE NX7.5 Drawing Error (Freed Object...)
we have the same Problem. The CSR told us that the new mp 7.535 correct the Problem
