Pumping station design
Hi, I am working in an irrigation project, and we have to design the pumping station (10 vertical turbine pumps and 1 in stdby. There are channels for water transportation from the river and we want to use the Hidraulic Institute Standards configuration for the sump with the same calculate values), so I will appreciate if anyone can give recommendation about pump station design (in this case water coming from rivers with vertical turbine pumps)(books, web pages with photos,articles will help). Right now I am working in the sump design and I am using "Hidraulic Institute Standards", "Sulzer Centrifugal Pump Handbook" and "Pumping Station Design" by Sanks. One of my main concerns is about using or not using separating walls, because I know that sometimes is worse to use them. Other concern is to know more about vortexes formation. These books recommends  Model Tests of Intakes, does anyone have done something like this?, does this represents the real pumping station?. Finally if anyone knows about companies that have gate, check and butterfly valves ranging from 30" up to 60" or more. Thank you in advance
RE: Pumping station design
Hi Pucp,
you are on the right way. If you use the recommendations from HI or the Sulzer Handbook you are on the save side. I am a Hydraulic engineer at the company Ruhrpumpen GmbH (www.ruhrpumpen.de). We often make proposal for pump sumps when we are offering pumps for these applications. To carry out model tests is only necessary if you are far away from the above mentioned recommendations. We have done this only one time in the past. It is expensive and takes time.
For my opinion I would use seperation walls. So you don't have an influence from one pump to the others. The flow will nearly the same in each chamber. But the design of of the channels before the chambers are also very important. Not too high velocities, not to large expansion angles etc.
Companies for large valves are: ERHARD,ADAMS, KROMBACH, VAG, MANNESMAN DEMAG. All these companies are located in Germany.
I hope this could help you.
  Hi everybody
   if anybody could assist me in the points and regulation regarding testing a pump for its Q-H diagrams in factory any codes and standard?
  Hi everybody
the US Army Corps of Eng has a complete design manual on pump stations
http://www.usace.army.mil/inet/usace-docs/eng-manuals/em.htm
then
EM 1110-2-3104 071  CECW-ED Structural and Architectural Design of Pumping Stations 30 Jun 89
EM 1110-2-3105  169  CECW-ET Mechanical and Electrical Design of Pumping Stations
could life be any easier....
when you get that big bonus, remember your friends in here
Keep the wheels on the ground
Bob
showshine@aol.com
