IBC - Load combinations when uplift is present ?
I have a concrete beam on soil (expansive, uplift pressure)
Span = 30 feet (ends fixed)
if My loadings are (plf - pouds per linear feet):
WLu = 1500 plf (uplift load)
WL = 500 plf (live load - gravity)
WD = 600 plf
What if the load combination and what will be the factored linear load (LRFD) ?
Because I understand that the live load will counter some force of the uplift, meaning that WLu = (1500-500) = 1000 uplift
WD = 600 plf
RE: IBC - Load combinations when uplift is present ?
I've not ever designed for actual soil uplift (swell from expansive clays) before. I don't know how you can quantify it that exactly. Usually for expansive clays you try to avoid soil contact (crawlspace, etc.).
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
I designed a post-tensioned slab on grade in Texas and recall that you are not designing for a force as much as you are designing for a movement. Consider the soil expansion to be similar to thermal movement and detail to allow the movement rather than trying to resist it.
Design considers that expansion pressures exist, but not necessarily in quantifiable form, so separation as Mike and JAE have noted is appropriate for design.
