Can True profile dimension be outside the Profile tolerance zone
Wether Profile tolerance can be given to a surface, for which the Basic dimension should be outside the profile tolerance zone.
For a size dimension 50 +2/+1 can we provide unilateral profile tolerance. The mean value is 51.5, and nominal value is 50 (Upperlimit is 52 and lower limit is 51)
This is a unilateral profile tolerance, but the true profile lies outside the Profile tol zone.
Whether the above dimn can be used shown with Profile of Surface callout ?
How the callout can be made for profile?
Please provide your suggestion
Thanks and regards,
Prabhakar
Thanks and regards,
Prabhakar
RE: Can True profile dimension be outside the Profile tolerance zone
So, the true profile cannot be outside the tolerance zone.
Dave D.
www.qmsi.ca
John-Paul Belanger
Geometric Learning Systems
I would disagree with the statement of +/- tolerances, at least with ASME. The absolute limits are the top and bottom of the +/- range. No part of the controlled feature can fall outside that boundary, same as GD&T.
Matt Lorono, CSWP
Lorono's SolidWorks Resources & SolidWorks Legion
Follow me on Twitter
See Fig. 6-13 in the 2009 edition of Y14.5, where it gives the dimension of 16f7. We could call that pin a nominal size of 16, even though the real limits don't include 16.
Also, as a disclaimer, I don't like the plus/plus or minus/minus deal. I'm just telling how some people do things. :)
John-Paul Belanger
However I am curious of your thoughts about following:
Take a look at fig. 8-27 in Y14.5-2009. (I know we debated about it some time ago and there were different opinions on mixing coordinate dimensioning with profile callouts). If you put 50 +2/+1 dimension instead of 80 +/-0.2, would profile of a line (surface) callout be totally illegal? Since the location of profile tolerance zone is not tied with theoretical perfect distance of top surface from datum A and can float within dimensional tolerance, would you say profile control couldn't be used in such case?
It is just my idea to keep the discussion alive...
Peter Truitt
Minnesota
I thought you were going to bring up Figs. 8-17 and 18. I think it was Evan who always disliked those figures, and I kind of agree -- a profile tolerance must always be applied to a "true profile," and the GD&T on those cones is not applied to a true profile as defined in paragraph 8.2. Instead, they show a toleranced diameter! Sorry to digress.
John-Paul Belanger
I was just trying to somehow satisfy OP's question by bringing up a situation when profile tolerance zone can actually lie outside nominal dimension. If we are in agreement that 50 +2/+1 dim. together with profile (of a line or a surfce) callout works fine, we are having a case when profile tolerance zone is completely outside nominal dimension 50.
John-Paul Belanger
The profile of a line tolerance in Fig.8 -27 is 0.07 and is inside your size tolerance of 50 +2-1. This example is an exception rather than the norm for the use of profile tolerance. You have a 3 size range while the profile has a 0.07. In this case, the feature must meet both requirements and certainly is not illegal.
In most situations, your 50 dimension would be basic with the profile of a line tolerance of 0.07 would default to a bi-lateral tolerance so nothing can be above 50.035 nor below 49.965.
Dave D.
www.qmsi.ca
I was thinking of 50 +2/+1 dimension not 50 +2/-1, so the tolerance range is 1 not 3 and lies completely outside the nominal value.
I fully agree with you that fig. 8-27 is rather exception than the norm, but like I said, I was just trying to find an example that could prove that profile tolerance zone can lie outside nominal shape of a toleranced feature. If we assume that plus/plus tolerancing is acceptable together with profile callout, we will be having such case.
I conclude that (as of now), it is not possible to use Profile Tolerance for which the True profile dimn is outside the tolerance zone.
Profile tolerance can be unidirectional when True profile lies in upper or lower limit of the Tolerance zone.
Please let me know, if any examples are there for Unidierctional profile as above case.
Thank you,
Prabhakar
Germany
You are correct that a profile tolerance cannot be outside the tolerance zone of the feature if the linear tolerance was large and the profile tolerance quite small in comparison. This situation is quite rare.
In most cases, the feature is shown with a basic dimension reflecting its true profile (theoretical) and the profile of a surface (or line) is about the true profile. It defaults to a bi-lateral tolerance but can be unilateral depending on how it is shown.
The ASME Y14.5M-94 reflects phantom lines on either the outside or inside of the object line indicating a unilateral tolerance while 2009 version has a value in the feature control frame before the U (circle) and another value after it. The first value is the tolerance value on the minus side of true profile while the value after the U (circled) is on the plus side.
Inside a large linear tolerance, the smaller profile tolerance is range of the profile on the surface or line and can be located anywhere inside the upper or lower specification limits as shown on page 179, fig. 8-27. So this is the unidirectional that you were looking for.
Dave D.
www.qmsi.ca
I don't find this modifier what I would call intuitive, but that is the way it works... |Total Range of Tolerance (U) Amount outside (in the "plus material" direction) the true profile|.
Dean
www.d3w-engineering.com
I stand corrected on the U modifier. You are correct that the value in front of the U is the total tolerance while value after the U modifier is the tolerance on the plus side.
Dave D.
www.qmsi.ca
