File open error
File open error
File open error
John or somebody,
Our customer uses NX7.3.3.5 and he gets the following message:
>>>> Error code 580128 caught in file "O:\ugnx753\ip3\src\syss\dman\ind\OM_ReferenceTable.cxx" at line number 611
>>>> Error code 580128 caught in file "O:\ugnx753\ip3\src\ann\no\ind\Annot_AssociativityUtils.cxx" at line number 517
>>>> Error code 580128 caught in file "O:\ugnx753\ip3\src\ann\no\ind\libann_main.c" at line number 991
>>>> Error code 580128 caught in file "O:\ugnx753\ip3\src\part\no\ind\part_load.c" at line number 5467
>>>> Error code 580128 caught in file "O:\ugnx753\ip3\src\part\no\ind\part_load.c" at line number 8496
>>>> Error code 580128 caught in file "O:\ugnx753\ip3\src\part\no\ind\part_load.c" at line number 10077
Adding load status for D:\DATA-9\xxxx\31-099-9\NX-dokumentacio\31-099-9.prt - Attempt to write to freed object (580128)
Failed to read in part "D:\DATA-9\xxxx\31-099-9\NX-dokumentacio\31-099-9.prt" cpu 7.676, real 7.738
Partition info: RM:1 (0.3, 0.3) CM:1 (0.0, 0.0) EXP:1 (0.0, 0.0) PATT:1 (0.0, 0.0) OCC:1 (0.7, 0.7) KF:1 (0.0, 0.0)
Failed to load and update part "D:\DATA-9\xxxx\31-099-9\NX-dokumentacio\31-099-9.prt" cpu 7.676, real 7.740
Load failed "D:\DATA-9\xxxx\31-099-9\NX-dokumentacio\31-099-9.prt": CPU time: 7.676 secs, Real time: 7.740 secs
&MACRO MESSAGE_BOX -2, Could not open D:\DATA-9\xxxx\31-099-9\NX-dokumentacio\31-099-9.prt.
&MACRO MESSAGE_TEXT The following files could not be loaded
&MACRO MESSAGE_TEXT causing this open to fail:
&MACRO MESSAGE_TEXT
&MACRO MESSAGE_TEXT D:\DATA-9\xxxx\31-099-9\NX-dokumentacio\31-099-9.prt - Attempt to write to freed object
We find same issues on the GTAC but we can't find the solution to these issue.
Could you help to our?
RE: File open error
Things to try:
Reboot the system
Copy the file to another location
If it is an assembly, try to load with No Components
Turn off all loading of linked objects
Ben Loosli
