Watercad Printing Help
I have trouble to print out Detailed Table in WaterCad 8 and still dont know how! Any help would appreciate-Thanks
RE: Watercad Printing Help
You can select Report --> Element Tables --> Pipe (for instance). this will open the flex table for you. Just edit the table to place the fields you want to include in the report.
Then click on the Report button (the third one from right) and select to Report the current time step.. a window shall pop out.. edit the header and footer and save the file as PDF if you wish to.
