Underground Detention to Gravel Perc Bed
I am trying to model a 72" diameter underground detention system with orifices that discharge to an underground gravel percolation bed.  I have to discharge the first 1.2" first flush by infiltration only.
Having trouble know if I have modeled this correctly in Hydraflow-Hyrdrographs.
Any help would ge great!
RE: Underground Detention to Gravel Perc Bed
Enter the entire system as an above ground basin with a void percentage.  Then add in the exfiltration value located in the pond inputs.  You should either do a field percolation test or get a lab to test for the permeability.
Depending on where you're at, you'll need to show the system recovers in a given time period.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
