TORSIONAL B VALUES
TORSIONAL B VALUES
TORSIONAL B VALUES
AS PER CANADIAN CODE WE NEED TO FIND TORSIONAL SENSITIVITY.
WHICH IS RATIO OF MAXIMUM STORY DRIFT TO AVERAGE DRIFT. DOES ETAB GIVE THIS VALUES IN OUT PUT AUTOMATICALLY?
RE: TORSIONAL B VALUES
I don't believe it does. You may want to output the displacement values and then calculate outside the program.
I found out. It does.
Go to File>PRINT TABLES>SUMMARY REPORT....
It will print Torsion B values
