bounding box
bounding box
Good evening
I have a problem with a Journal file for extract the bounding box of the part.
I have this file but doesent work.
For me is very important.
Thank you very much.
By
By
RE: bounding box
I see the journal was written with NX6 in mind, what version of NX are you running?
RE: bounding box
Jenuary,
It looks like this was an unfinished program.
This should run now.
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Imports NXOpen.Assemblies
Imports System.IO
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim ufs As UFSession = UFSession.GetUFSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim strPart as string
Dim pos as integer
Dim bbox(5) as double
Dim dblAcc_Value(11) as double
Dim dblMass_Props(46) as double
Dim dblStats(12) as double
'''msgbox ("inizio")
Dim solid1 As Body = SelectSolid()
If solid1 Is Nothing Then
Return
End If
Dim tagList(0) As NXOpen.Tag
tagList(0) = solid1.Tag
'get the full file path
strPart = solid1.owningpart.fullpath
'''msgbox(strPart)
pos = InStrRev(strPart, "\")
'strip off the ".prt" extension
strPart = Left(strPart, Len(strPart) - 4)
'''msgbox(strPart)
'add extension to file name for parasolid export
strPart = strPart + ".x_t"
'''msgbox ("tag: " & solid1.Tag, vbokonly, "Tag")
'''msgbox ("file: " & strPart, vbokonly, "Part")
'export the solid to a parasolid file
'ufs.Ps.ExportData(tagList, strPart)
'get volume
dblAcc_Value(0)=.999
''' ufs.Modl.AskMassProps3d(in_Tags(),in_num_objs,in_type,in_units, _
in_density,in_accuracy,in_accuracy_values(),out_mass_props(),out_stats())
''' ufs.Modl.AskMassProps3d(tagList,1,1,1,.0375,1,dblAcc_Value(), _
dblMass_Props(),dblStats())
ufs.Modl.AskMassProps3d(tagList,1,1,1,.0375,1,dblAcc_Value, _
dblMass_Props,dblStats)
msgbox ("Volume: " & dblMass_Props(1), vbokonly)
'get solid body bounding box extents
ufs.Modl.AskBoundingBox(solid1.Tag,bbox)
msgbox ("min X: " & bbox(0) & "min Y: " & bbox(1) & "min Z: " & bbox(2) & "max X: " & bbox(3) & "max Y: " & _
bbox(4) & "max Z: " & bbox(5), vbokonly)
End Sub
Public Function SelectSolid() As Body
'''msgbox("passato a solid")
Dim ui As UI = ui.GetUI
Dim message As String = "Select solid body"
Dim title As String = "Selection"
Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
Dim keepHighlighted As Boolean = False
Dim includeFeatures As Boolean = True
Dim selectionAction As Selection.SelectionAction = _
Selection.SelectionAction.ClearAndEnableSpecific
Dim selectionMask_array(1) As Selection.MaskTriple
With selectionMask_array(0)
.Type = UFConstants.UF_solid_type
.Subtype = 0
.SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY
'.SolidBodySubtype = 36
End With
Dim selectedObject As NXObject = Nothing
Dim cursor As Point3d
ui.SelectionManager.SelectObject(message, title, scope, _
selectionAction, includeFeatures, _
keepHighlighted, selectionMask_array, _
selectedObject, cursor)
Dim solid As Body = CType(selectedObject, Body)
If solid Is Nothing Then
'''msgbox("Return Nothing")
Return Nothing
End If
'''msgbox("Return solid")
Return solid
End Function
End Module
RE: bounding box
thanks for the help, it's perfect.
I have a question for you:
is possible to get the total size 3 dimension?
In this exsample i have the minimun en the maximun X,y,Z dimension,
you can get the total dimension without adding parameters minum and maximun?
Sorry for my English, i'm Italian
Have a nice day
Jenuary
