Insight shared parts go to a folder or document library?
We are just getting familiar with SolidEdge ST3 Insight.
Some areas are still unclear to me.
Where do you place family of parts and common part files shared or use by designers in Insight?
RE: Insight shared parts go to a folder or document library?
Theodore
Solid Edge ST3 MP3 on WinXP x64
Insight Server on Win2008 R2 & SQL 2008 R2 x64
SharePoint 3.0 x64
Also I am noticing that I am able to save files doign a Save as in the Insight Released document folder even if I am not a member of the Eng_doc or the Doc_control group, is this normal?
With regards to document control the following:
1. Only members of the "coordinator" group can edit released documents.
2. Only members of the "engineering change" group can create revisions.
3. Saving or adding documents to the released document library are controlled by SharePoint groups. If you are a member of the site's members group you can read and edit documents. If you want to restrict a user to only read access he or she must only be a member of the site's visitors group.
SharePoint 3.0 x64
I do have a number of questions still that you may be able to enlighten me.
1)Can Solid Edge members who have contribute permissions able to do a Save As in Solid Edge and save in Released library?
2) Can Solid Edge member go thru Revision Manager and move files from WIP library to Released document library?
3) Can Solid Edge members add unmanage files and use LifeCycle assistant and directly add it to the Released library?
4) When saving or adding files in a managed library, do the users have to define the File Properties as In Work or Released prior to saving to the respective document library?
Lourdes
