Method for shaker test-analysis correlation/validation
Please give any comments or suggestions...
A metallic assembly with bolted joints, is mounted on a composite structure. It has been designed and analysed, with the FEM including the composite structure; the critical stresses have been derived. Now, a sine-sweep will be performed with shaker connected to the composite structure.
To avoid damage to the hardware, the accelerometers will be monitored. The prediction method is as follow:
1. Accelerometers are placed on various parts of the metallic assembly.
2. Analytical FRFs for the accelerometers and critical stresses are derived from FEM.
3. The analytical acceleration FRFs are compared with the stress FRF; the matching accelerometer(s) will be used as the control to monitor the critical stresses.
4. So, at a certain resonance the magnitude of the control-acceleration is assumed to be proportional to the stress at the same frequency.
5. The sine-sweep will begin with a low-level excitation. By looking at the peak acceleration response at the control-meters, the stress is extrapolated to full-level value.
6. The extrapolated stress is reviewed before deciding to go to full-level sine-sweep.
Any help is appreciated.
Thank you all.
RE: Method for shaker test-analysis correlation/validation
This seems like a rather long and drawn out approach to using an experimental modal analysis to get the damping of each mode, which your FEM can't tell you.
So, if I were you I'd get an EMA of each component free-free, and the assembly, and compare mode shapes etc with the FEA.
Once that is all as good as you can get then your approach above may be appropriate.
Cheers
Greg Locock
New here? Try reading these, they might help FAQ731-376: Eng-Tips.com Forum Policies  http://eng-tips.com/market.cfm?
