How to accomplish Unicode file I/O operations in Fortran?
Has anybody managed to get "File Open/Inquire" operations working in Fortran (Intel v.10.1) with a Unicode filename, such as Japanese?  Any advice will be greatly appreciated.
Richard Ay
Intergraph CAS
RE: How to accomplish Unicode file I/O operations in Fortran?
You need to use the NLS functions.  Under Fortran help, type MBCS Conversion in the search line.  It will come up with a whole bunch of routines.  The ones you're interested in are the JIS ones.
Note that Japanese is not normally unicode: it is normally DBCS, which on an MS system can be mistaken for unicode since they are both 16 bits.
Thank you, we'll check this out.
Richard Ay
Intergraph CAS
