Using the Join feature with Configurations
Hi all,
I've been searching for a while, but can't find a way to change the configuration of one of two parts that have been joined together.
Thanks in advance.
RE: Using the Join feature with Configurations
Same as in a regular assy ... select the part, click the properties icon, and select the config.
What is happening when you try?
That's a Combine ... which is used in a part!
The thread title stated Join ... which is used in an assy.
Apologies, it is a combine. I am not an expert with Solidworks by any stretch of the imagination and it was the first time I had used the features.
That said, any insights on how I change the configuration of a part in a Combine? Or do I have to recombine them?
The config can be changed under the List External Refs option.
I'm running SW2010-SP4.
This was a while ago, so hopefully I'm not forgetting a step.
Opened the edi top test slant.SLDPRT file
Went to Insert->Part
Selected transducer.SLDPRT
Positioned the transducer housing where I wanted it on the case
Clicked Combine, Add then ok and the two parts merged.
Try inserting both parts into a new part, and then Combine.
The configuration option should be as CBL stated... in list external references.  It was there as far back as I can remember... ~2003 at least.
-Dustin
Professional Engineer
Pretty good with SolidWorks
Thanks CBL, that worked a lot better. Now I have access to the configuration options again. Thank you so much for your help!
