Gas Hydrate Formation
Afternoon all,
I am currently reviewing a gas compression package which has relief valves coming from the system to the flare. What has been asked is the potential for hydrate formation in stagnant lines.
When considering the layout of the pipes, there are some dead legs and some slanted horizontal pipework. The pipework is open to atmosphere and can have wind blowing into it. Would hydrate formation be a possibility if fluids were dropping out? I would assume that having self draining pipework I would be able to presume that if an accumulation were to form it would simply be a fluid accumulation rather than a potential hydrate i.e. the fluids would drop out but not instantly freeze?
If I knew the temperature profile through the pipework and the pressures along with composition would I be able to calculate the hydrate formation potential in stagnant pipes?
Thanks in advance
Thanks in advance
RE: Gas Hydrate Formation
If you look at GPSA Field Data book figure 20-15 you'll see that the minimum hydration formation pressure at 32°F is 70 psia. For Methane it is 400 psia at the freezing point of water.
I've never heard of hydrate problems downstream of a PSV. Upstream is another issue altogether.
David
David
http://hydrates.mines.edu/CHR/Software.html
with it you can predict when you will hydrate off.
We may be mincing words, but at atmosheric pressure you can have hydrates of the other consitiuents in natural gas. ALL nat gas is not 100% methane.
I've collected the ice balls from leaking propane at a flange and taken that ice ball and packed it into a snowball and put a match to it, it sure makes the nubies at work nervous to see ice burning.
This propane mixture has a hydrate potential at 5 psia! (at -40f)
I worked on the periphery of a flow-assurance problem once where a well stream at 10,000 psig was in 6,000 ft of 40F water--hydrate point of the flow stream was 72F and the thermal entry length was under 200 ft, so the stream would be a 40F slushy a mile under the ocean surface. This was a serious problem. Worrying about whether hydrates will form at 25F doesn't seem serious since at that temperature the water vapor will condense and freeze as water ice which is a bigger problem than hydrates.
David
Hysys can be used to predict the Hydrate formation temperature of a particular gas composition / fluid composition presuming free water present.
To mitigate this, if it is a great concern, heat trace the stagnat lines to maintain a temperature abouve this point - put a safety margin in - say 10 degrees.
I hope this helps.
Alex Chatwin
