Precast beam sections
Hi all,
Im not a civil/bridge engineer, more mech design.
I have a question regarding precast beam sections of bridges;
If you have the section dimensions is there a standard to which you can come to the max load?
ie; HE-A / HE-B section girders? properties as an example?
also is there a standard to which the steel rods / stifferners are layed out?
thanks.
thanks.
RE: Precast beam sections
its a vague area....
