Equation Derivation
Equation Derivation
Equation Derivation
Hi I was hoping someone could tell me where this equation was derived from,
dP=2*A*pi*Hz
where,
dP= Change in pressure
A: Amplitude
Hz: Frequency
RE: Equation Derivation
A is the peak pressure amplitute
2*pi*HZ = rotational velocity = omega
pressure rate of change = dP/dt = A*omega = A*2*pi*Hz
Imagine a disk of radius A spinning at rotational speed omega.  The radius rate of change is A*omega.
Ted
Ted thank you. There is another potential question but I will think about it a little further before I ask.
Thank you once again.
