Greenish sulphur in SRU
S!
In a sulphur recovery unit was found greenish sulphur in one of the seal legs.
The SRU process acid gas from a Sour Water Stripper and a Amine Unit.
There are suspicion of ammonia contamination from SWS or even DEA from Amine unit.
Anyone faced similar problem?
RE: Greenish sulphur in SRU
HAZOP at www.curryhydrocarbons.ca
So, would the "copper" be from the trace chemistry in the other metals and would it be enough to produce this byproduct in visible quantities? Otherwise, I would ask where the copper (yellow metal) would (should?) be present in an SRU, or where it's coming from.
SNORGY.
