Multiple shot impacts, what load type to use?
Hi everyone,
I am trying to simulate the shot peening process in Abaqus. Large number of shots (approx 10 000 shots) impacting on a metal surface and creating compressive residual stresses.The shot-shot interaction in the shot peening process is simulated in a different application and I would like to apply the forces acting on the treatment surface in Abaqus.
What is the appropriate load type to use in the simulation? Concentrated force, pressure, surface traction etc.?
The simulation is very computational and I would like to use a load type that requires less computation time and that provides reasonable accurate results.
Thank you for your help.
RE: Multiple shot impacts, what load type to use?
Create a small (low element count) representative model and try a bunch of simulation strategies until you find the one that works best with the following metrics (time, accuracy, robustness). Robustness: if you make a tiny tweak does it still work such as a remesh.
Maybe someone has done a similar analysis if so they will probably be more help. Once you have the simple model setup you can also post it here since it is unlikely that it holds proprietary information. I hope this helps.
Rob Stupplebeen
https://sites.google.com/site/robertkstupplebeen/
Thank you for your suggestions Rob.
My output odb file is exceeding a few hundred GB. Is there a way of reducing the file size by change the History or Field Output interval?
Rob Stupplebeen
