Fatigue Properties of Hiperco 50HS (Iron-Cobalt-Vanadium alloy)
I can't find any fatigue properties of Hiperco 50HS.  Does anyone know where i can find data such as Fatigue Strength Coefficients, Fatigue Strength Exponents, or S-N Curves?  Are there any rule of thumbs when cyclically loading this material?  I'm using this material for its magnetic properties.  here's a link to the data sheet...
http://cartech.ides.com/datasheet.aspx?i=103&;e=198&;c=TechArt
RE: Fatigue Properties of Hiperco 50HS (Iron-Cobalt-Vanadium alloy)
I was just looking for fatigue information on Hiperco 50HS and found this forum.  Did you ever obtain the data you were looking for?
Call the vendor??
Here's a link to MatWeb: http://www.matweb.com/index.aspx
Have you looked there? Or, as Mike suggested, called the vendor?
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
what heat treat ? strength is a trade-off with fatigue performance
