Moisture EHV Cables
Moisture EHV Cables
Hi every one
A EHV cable was cut and left exposed to High moisture and water( no cap at either end of cut cable ) , i know about effects of moisture on cable specially on insulation deterioration also i know there are methods to dry out MV cable such as using N3 , To make the long story short can i still use this cable ? Is it possible to use these methods on EHV cables?
Considering absorption rate (by time) of different materials is it possible to point out a spot(From exposed ends ) on cable which after that point cable has not been effected by moisture during that X amount of time?
Thanks .
Have a good day .
Thanks .
Have a good day .
RE: Moisture EHV Cables
