Run Around Coils
Run Around Coils
Run Around Coils
Hello there,
I'd need some help for following issue.
I'd like to find a method for run around coil calculation.
When looking to past threads, I found some references to ASHRAE (thread403-249667: Coil Energy Recovery Loops).
I tried to consult them but they weren't exhaustive.
Neither google gave me detailed pieces of information.
Please, could anybody of you give me some tips or references for this selection ?
Many thanks
RE: Run Around Coils
Hello, many thanks.
It is a first step ahead, but if you see there are some restrictions.
As you can see, the coils row number is always limited to 8.
In this case one degree of freedom in the system is eliminated.
Many thanks
http://www.greenheck.com/software
Check out the Caps software and the coil selection software, one of them has the run-around coil selection in it.
