Lateral sway of Vertical Bracing and Moment Reisisting Frame
Hello All,
Do you know any shortcuts (prefereably Graphical Solution) to calculate the lateral sway of Vertical Bracing or Moment Reisiting Frames in low/medium rise buildings? I know I can calculate it with "Virtual Work Method" but this can be lengthy!
Many Thanks,
Many Thanks,
RE: Lateral sway of Vertical Bracing and Moment Reisisting Frame
