About MSC Fatigue
About MSC Fatigue
About MSC Fatigue
i am using MSc Fatigue, when i want to apply a timehistory load using PTIME it is showing error that it "can not edit internal files"
How to solve the problem ??
RE: About MSC Fatigue
I had a similar problem. For some reason, MSC Fatigue would throw me errors unless I was working in the following directory.
C:\WINDOWS\Temp
You should do this to resolve your issue.
1) Restart your computer
2) Either start from scratch and save your file in the directory above, or move your already saved file to the directory above and open it from there.
